98 vs 99 brake systems
rjlichau
45
Jul 8, 2006
Santa Rosa, California
I was wondering if there is a significant difference between a 98 turbo and a 99 turbo rotors and pads cause I was looking to get some new ones through a sponsor, but they only had up to 1998. Just wanted to make sure that everything would fit if I got some.
Thanks
Since you are sponsored you could try and talk them into getting you the calipers, rotors, and pads for a gsx. In case you didnt know what the benefit is it would be larger rotors and pads along with dual piston calipers instead of the FWD's single piston calipers. It is a simple bolt on and it will give you more stopping power.
Thanks for the Info I will try to talk to them. :thumb:
