Resolved 98/99 ECUFlash
watson95dsm
Sep 21, 2010
slanesville, West Virginia
i have a 95 gst some supporting mods still with the tslow...wondering what else i need to change other than the CAS from a my 98 gst and do i have to pull the intake cam or does the 95s have a grove in them for the CAS
Nothing. You really don't even need to pull the CAS although I suppose it would make it a little easier. The 95 cams have the slot in them already. As long as you add in the wire to the ECU harness for the flash connector you should be GTG.
