420A 97 GS Clutch issues??
It is an OEM clutch. But I think I may have found the problem. Finally, I lengthened the rod a 1/4 inch and tried it, Got nothing from it. Same results as before so I said screw it and drove it around the yard to warm the trans up. Same thing as before grinds. So I took it around the block and went through all gears. Finally something, The thing grinds into first, second, and third. But into fourth and fifth gear it is fine. So im thinking that the lower end syncros are garbage. But when I drained the trans fluid there were no shavings and the fluid was not gritty at all. Any other advice on what else it would be??? And how hard are the syncros to replace and where can I get some??
