clutch engagement issues 3.55 swap with non modular clutch
rideyamaha287
49
Nov 5, 2008
Las cruces, New Mexico
ok guys i just got done finishing my build and i cant get my freakin clutch to engage at all. ive bleed the entire system like a hundred times changed the slave cylinder. So i have a neon gear box with a centerforce pp and act 6 puck disk. Ive double checked every line/fitting. one thing i notice is the slave cylinder piston looks fully extended in the slave housing. i dont know if that makes a difference. its really pissen me off been trying to bleed it for 2 days now i search online tried different techniques im really lost now guys im going crazy with dam car...:banghead: i really dont know what else to do. i might have to drop the trans again to see what the heck is going on in there...bummer
What flywheel. I suspect (as talongirl is alluding to) that you may have a step height problem. You definitely have a 420a ACT disc in there correct? And it the dimensions of said disc correspond with the pressure plate and flywheel to come up with the proper step height? I know there are questions on Fidanza's flywheel step height using on "other's" parts.
MB
