95 talon electrical issue's (rewiring underdash)
7018stick
Jun 4, 2013
threehills, AB, Canada
1st off, im an old school gear head trying to help my 16 year old son with a project 95 talon 2ltr esi, 5spd, our problem has been that it wont start. The guy we bought it from said it was the fuel pump and gave us a brand new one he had ordered. What Ive done so far, installed new fuel pump, nothing! installed new fuel pump relays, pump primed 2 or 3 times then nothing! changed ECU and fuel pump relays and it fired right up,,, we drove it around for a half hour or so starting it several time's,,, The next day nothing!!! Ive pulled the dash apart to find a nest of aftermarket alarm,old stereo, and blue lights, I believe "he" took out his amp and sub's before we looked at the car and "he" left us a short thats blowing the ecu and/or relays,, so Ive removed all "extra's" and rewire'd (via hains manual) all but the main ignition/starting harness right from the key,, I could sure use a pic of the factory plug in right underneath the steering colum that comes from the key/ignition to the harness, If anyone could give me a pic of this I/we would be greatful!!!:banghead:
OH,, P.S. please laugh,,, what is 1G,,2G,, I dont know what we own!! :)
Hi, Sorry I cant help you with a pic, Because I have a 1g, The difference between a 1g and 2g is the year. The 1g's are 89-94 and 2g's are 95-99. You have a 2g.
Have you checked the fuses? I'm sure you have , Just checking.
Does the motor turn over?
yes it does turn over, everything else works fine eg; lights,signals,stereo ect,, just no fuel pump untill I changed both ECU and FUEL relays?? Thanks on the 2G!
just one pic is all I need? some one must be installing a stereo or alarm in their 2G somewhere? Ill I need is a pic of the wireing harness under the steering colum where the ignition/key connection is,I just need to see the wire colors on either side of the connector as ours has been cut out and we need to wire properly. Ps, I have been to the wreakers searching,, all have been hacked worse then ours!!
Sigh, hacked ignition harnesses are a common thing on DSM it seems. I just pulled a new interior harness for mine and it's all hacked up too.
I can take some high resolution pictures for you of the wiring diagrams from the factory service manual later on today after I'm done school (5pm-ish NL time).
EVERY dsm practically. Previous owners always rigging shitty alarm systems and "turbo timers" . Mines jacked too bro. Soon as i get back from my wedding im tearin into the wiring so maybe i can post some pics for ya. good luck
