90 DSMlink questions..
91DSMdave
223
5
Jun 23, 2009
Strattanville, Pennsylvania
I have a 90 laser, and im looking to get dsmlink.
If i get a 90 eprom and get it socketed, can i use a dsmlink chip and whatnot that came out of a 91-94 with no problems? I read something about having to modify something else other than switching pins 6 and 14, if i switch to a 91-94 ecu?
when i get this setup, where can i get a base tune to upload, just like a stock tune?
Anyone? I will be getting this very very soon and need to know
If you get a '90 EPROM ECU, yes you can install ECMlink after you get it socketed.
Not sure what the reference to the '91-'94 stuff is about.
You can just set your injectors on ECMlink and be ready to go. It uses the "stock tune" (if you want to call it that) so you won't have to change or load anything.
