GVR-4 89 JDM Galant base timing out 180
CanadianTalonTC
582
97
Jul 8, 2011
Lethbridge, AB, Canada
Hey guys,
Helping out a new friend with his JDM Galant.
Completely stock, working on fixing all the boost/vacuum leaks etc etc. It was 1 tooth out of time so I retimed it with him, however unless the lower cover has changed at some point I cannot seem to set base timing. It shows 180 degrees out every time. I even rotated the CAS 180, didn't change anything. When you move it left and right my mark moves, but still on the opposite side of where I would expect.
I have tried plugs 1 through 4 for reference.
Do I need an adjustable timing light to go -180? I feel like I'm missing something obvious here. I have a 2gb 7 bolt so I'm a little lost.
Other notable events is it makes 5psi of boost max and feels like you are driving an N/A. Hoping once all the leaks are resolved this improves immensely and I have highlighted the importance of prioritizing this.
Thanks.
Hey guys,
Thanks.
Did you rule out the harmonic balancer itself?
Check the timing light is not set to 4 stroke vs 2 strokes if it has this feature as can be completely out if it does. I tested mine out recently and it did this when i checked 4 stroke (V8 types)
Just another thing to check
I have not but that definitely is a great idea and I'm a little annoyed I didn't think to do so. Do you care to spoon feed me the info on testing? I am also going to head to google right now.
Thanks.
Easiest way would probably be to use the screwdriver method to set #1 piston to TDC and then check the mark. It should at least be close to the cover mark.
It was a very basic timing light with literally an off and on button, we may need something slightly closer to this century. I don't own one since I am 2gb so I'll try and track a better unit down.
Big "duh" moment. IIRC it did, but I will double check again.
