GVR-4 89 Galant GS ABS delete
johnboyrs
59
May 28, 2011
brownfield, Texas
Ok, I have this 89 galant gs with abs and I want to take it out and have a couple of 1g shells without abs can I do this with the hard lines?.....also has anyone seen a factory air ride system on a galant????
You can do an abs delete, but idk if 1g lines will match up. Can always bend/flare you're own lines from the distribution block to the fenders. Rear lines should be the same I believe.
Factory air ride? Never seen or heard of a Galant having it, but I don't keep track of galants really.
Thanks. Yea I'll get some pics today, you know on vr4s they have a clock on the center dash mine has ride modes of sorts.
I removed my ABS on my 91 Gvr4. No need to flare your lines. Autozone/parts store carry lines. I ripped out the old front lines and measured them. Of course I couldn't mimic the bends exactly so I did have some slack. It's a Japanese lines 8mm x1.0 I believe. Take the end with you to make sure you have the right line or even a brake hose.
You need a non abs prop valve as well. The rear lines just need to be slightly bent to match the valve but its fairly simple. I also replaced the metal line at the strut since mine were rusted and I cut them out.
