Pirrofab
- 726
- 40
- Sep 2, 2006
gouldsboro,
Pennsylvania
please post a log? My car and I are only dreaming of making 425-450whp on pump with meth. Damn I need someone with dsmlink in my area to lend a hand with my set up.
In the first video is sounded like you actually lost traction in your pull at 10 seconds.
so whats the top speed on 5th?? i really want to see? is it like that with awd as well?
congrats bro!
thats how we street tune around here
didnt we meet over in osw and then you went to IFO gainesville?
I'm currently getting my twin scroll manifold fab'd for my 7-blade HX35 with a 12cm^2 non-wastegated housing.
What rpm are you seeing 25psi by?
Nice!, I remember seeing your manifold in the Part 8 thread.with a twin scroll manifold and stock housing (12 cm) the hx35 sees 25+ VERY EARLY.
Is yours a 7-blade?
What rpm do you see 25psi by in 3rd gear?
Is yours a 7-blade?
That was 25psi + in 5th gear by what 3200rpm?
8 blade. My turbo doesnt spool that fast since I have the stock backhousing and a open manifold. Probably around 5k in 3rd. Im not 100% sure honestly. The car still has a good powerband. I just break boost so it doesnt lag and at the track it never falls out of boost.
The stock 2g intake manifold/throttle body suck. Since I don't have any head work the evo3 is a good combo.
That's fast, but testing spool in 5th is dumb there is a shit ton of load on the car and while it might help show what it would be like cruising on the highway it won't help with the 2nd or 3rd gear rolls.
I can say if i did it again, i would do TS with TS, buy richard has shown us what it can do open to TS, good job again.
I'll get back to you later.That's fast, but testing spool in 5th is dumb there is a shit ton of load on the car and while it might help show what it would be like cruising on the highway it won't help with the 2nd or 3rd gear rolls.
The effects of a true twin-scroll setup versus an open manifold mated to a twin-scroll housing.Mine also spools extremely slow. I get 25-30psi by 5500rpm. Its most likly the wrong manifold set-up. I wonder if this effects output of the turbo if it effects spool so much?
