HX35 pump gas dyno
GSXbooster
Supporting Member
178
140
Jun 3, 2003
Centennial, Colorado
I plan to road race with my car. It was tuned very conservatively, ZERO knock.
Setup:
Wiseco/Scat 2.0
stock head - stock cams
1g throttle body & Evo III intake manifold
ARPs
Holset HX35 7-blade
BEP .55 bolt-on housing
FP Race manifold
Tial 38mm / Punishment racing recirc o2 housing
FIC 1250cc
Walbro 255 hp
Numbers:
370whp & 343 torque
Full spool - 23 psi around 33-3500rpm.
91 octane pump gas.
E85, 272 camshafts and Forced Performance's FP30 style turbine housing are in the plans. But I'm loving this turbo in this configuration so far!
Very fast spooling turbos for how big they are and what they are capable of flowing. I am happy :D
What's your compression ratio?
8.3:1 wiseco standard pistons
Thats cool. Im still waiting on my cams to get here, and im ordering link this week. Ill be running the stock turbo on my auto until i get used to link and get some other odds and ends squared away. In the meantime im saving my holset money LOL
With those changes listed, I see 500+awhp at around 35-38psi EASY!
Good numbers! Can't wait to see what the HX35 will do with my evo piston setup in a stalled auto car.
Not bad at all!! Whats the peak timing?! Air flow?? This makes me feel all fuzzy inside.. Cams and e85 for sure!!
I was seeing ~ 52 lbs a min at 26psi, 9* of timing on 93 oct with my 7 blade hx35 last summer. However I was on 272 cams and the t3 stock turbine housing.
This makes me happy. You have pretty much the same setup as me. Minus the intake, but I think my 272s and crower springs should make up for that, and we have 93 oct :p.
I'd try the E85 and 272's before swapping out the turbine housing. Those two alone should be more than enough to make another 150hp without increasing spool time.
