7 bolt FWD flywheel?
g4ebguy90
2,001
3
Mar 9, 2011
Rockford, Illinois
Hi all, im doing a 7 bolt NON-turbo 4g63 build, and im wanting to buy a lightweight flywheel. I cant find one though for the FWD, just for the awd. anybody know were i can get a FWD 7 bolt flywheel. thanks
OoOoOo.... hey some guy very close to me has a 7bolt Turbo flywheel, would this work on my non-turbo?
Turbo and non-turbo flywheels are not the same and are not interchangeable. You could use a turbo flywheel, but you would be required to use a turbo transmission and clutch kit with it.
so if i install a turbo trans, do i have to do anything else to the car to make it work? diff axles, hubs?
I thought N/A 4G63's have the same flywheel. I'm using a head off a NT on my turbo car...
Axles depend on the year of turbo transmission you get; '93+ FWD axles are thicker, specifically on the diff side, meaning an earlier axle will not fit the diff without modification. Hubs should be the same regardless.
http://www.dsmtuners.com/forums/drivetrain-tech/229538-1994-fwd-tsi-axle-question.html
http://www.dsmtuners.com/forums/maintenance-repairs/376823-94-tsi-fwd-axle-problems.html
They don't. Heads are not the same as flywheels. :D
i got a response from that road race enginnering place, they said they have a flywheel but id have to use a TURBO clutch???? sounds odd to me, seeing how the flywheel should be made specifially for a non-turbo???
You might want to call back and confirm what it is they told you. As far as I know, a turbo clutch disc cannot be used with a 1G non-turbo flywheel.
i sent a reply, and
1. They didnt answer my question regarding compatibility, they just keep saying, you need to use a turbo clutch and then they said is your car making a bunch of HP???? im not doing business with them.....
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
