mihai clotan
- 0
- Sep 13, 2012
ft lauderdale,
Florida
This is a problem that has been stoping me from finishing this project. The motor has been re-done, but i cant get the car to run good. It starts on the dime, idles good for few seconds, than goes rich..than lean ..than rich again, i get unburned fuel coming out of the exhaust, idle turns rough.
- I checked vacum's, gas, wiring of cas, its all good.
- I had guy's who swear they can fix it in a minute, and end up scratching their heads.
- Everything that is available here, on the forums, i have or someone else has tried ....we replaced injectors, we replace fuel pump, pressure regulator , firing order , injector oder.....
This is the problem i think i have : the motor is a 92 6 bolt, the ECU 96, the car 99 GSX....cams are GSC S2....between the timing, the injectors and spark there is no good communication.
If anyone here know's how to set this things for my specific set up , will be a sooo helpful.
Thank you.
Thank you.
, go around the motor and listen for air leaks....he found some , one was at throttle body. I did fix them , however i never replaces seals on throttle body.
