68hta pics...help
rowdygst
230
Jan 12, 2011
san antonio, Texas
well i have a 5031 pte turbo that im trading for a 68hta, cause im not looking for crazy power maybe like 370-380whp on 93oct and meth, well the 68hta has bent fins cause the previous owner sucked in the o2sensor wire, the turbo has no shaft play, it dont smoke it boost fine, and the car has gone mid 11's at 120+ traps on the codition it sits, it just makes a whine sound under boost cause of the bent fins.. now i have talked to fp about buying a new compressor wheel.
so my question is this, would i be able to run the turbo with no problems? this would not harm my engine, or should i run my big 16gtill i can get the 68hta a new wheel? i know it seems kinda like a dumb question, but i just got done rebuilding my motor and dot want to harm it, i doubt this will affect the motor but just want to make sure
It's really not worth the risk of it possibly being injested into the engine is it? The answer is simple. Run the 16g until you get the 68 fixed like 96WhiteTSi already said.
It will also be terribly unbalanced. If you run it, it will be forcing the turbine shaft into the bearings destroying those and the shaft making it need more than just a rebuild. A buddy of mine dropped a e316g with no compressor cover, damaged the compressor wheel (chip) - tried running it...you could hear that poor thing cry. I got it for free and it needed a rebuild. Wasn't even on his car for maybe 10 miles before the bearings were torn up pretty good. Don't run it.
Ok, ill run my 16g untill I can buy a new wheel and re balance the turbo
    • dsmmario
    • Detail
    • dsmmario
    • my98gsx
