erkitner
- 99
- 0
- Oct 24, 2011
Olympia,
Washington
So my 98 GSX walked and I've done a 6 Bolt swap with a 2G Head. After tons of research, and a few of my own oversights (1G Cam Angle Sensor
) she fires up and moves on her own power.
Here are my symptoms:
Idles fine but REALLY lazy on acceleration.
After 10 minutes of driving she suddenly LEANS out. Bad. Like 17. Then sounds like a WRX. (Obviuosly bad)
No boost. No indication of boost.
Positives:
Perfect indication of Water Temp, Oil Pressure, Vaccuum (again no boost), Speed, and RPMs.
Compression test: 180 across the board (No BS). I built her right.
Just serviced a couple days ago: Rear Diff, Transfer Case, Transmission, Oil Change (All Pennzoil). So she's fully serviced and all fluids good and in working order.
Here are my mods:
Evo III Big 16G Turbo
GReddy 24 Row FMIC
GReddy Type RS BOV
650cc Injectors
GReddy Turbo Timer
Apexi Full 3 Inch Exhaust (No Cat)
2G Head
6Bolt Block (93 GST)
Forced Performance Turbo Manifold
3 Inch Downpipe
DSM Link v3 (MAF Bypassed)
ECM Tuning Cable (2G OBDII to USB)
Manual Boost Controller
Extreme PSI Couplers
Eibach Springs
Magnus Motorsports CAS Harness
6 Bolt Specific:
OEM GSX Pistons
OEM 91 Galant VR-4 Rods (bored to fit 2G Wrist Pins)
Other issues:
I can't get DSM Link working. I keep getting a "communication failed". I configured the ports and my computer is using COM7 to run DSM Link. Device Manager is also showing COM7. I bought a BRAND new Tuning Cable from ECM Tuning (old one gor severed) but I'm still not getting the green light to turn on. WTF???
Also I found a broken part on my car and have NO IDEA what it is...or whether it's important enough to get my issues I'm having. I've posted a picture so any help with this would be appreciated. I was mounted by the firewall on the passenger side close to the throttle body. I'd like to replace it, but don't even know what to look for. Haynes has nothing on it.
The casting mark is:
K5T49683
7619
Looked up the number online and all I get is German stuff. ???
She starts, idles beautifully, drives like an NA 2.0 for 10 minutes then LEANS out.
No boost.
Turbo worked fine intil the walk. Have not replaced the turbo or anything like that simply because it was fine the whole time.
To sum it all up: No boost, No DSMLink connection with NEW cable all else is fine.
HAAAAAAALP!
HAAAAAAALP!
She's my pride and joy and need her to dominate at 18PSI again.
Thanks, all.
-Eric
) she fires up and moves on her own power.Here are my symptoms:
Positives:
Here are my mods:
GReddy 24 Row FMIC
GReddy Type RS BOV
650cc Injectors
GReddy Turbo Timer
2G Head
3 Inch Downpipe
Eibach Springs
6 Bolt Specific:
OEM GSX Pistons
Other issues:
K5T49683
7619
No boost.
HAAAAAAALP!
HAAAAAAALP!She's my pride and joy and need her to dominate at 18PSI again.
Thanks, all.
-Eric
