4G64 7bolt crankshaft from 3G or 4G
ZLODEY
85
Sep 9, 2006
Vilnius, Europe
Can I use 2.4L Eclipse 3G or 4G (4G64, right?) crankshaft (7bolt?) in 4G63T 7bolt stroker. Do they all use the same MD346026 ? :rolleyes:
*Blows off the dust* *Hits the bong*WTF
Can the crank off a 3G just slip into a 6 bolt block? I'm thinking of tearing one out of a yard car.
Also, would that require a 7-bolt oil pump case? Or just keep the 6-bolt oil pump case?
you can use a 2.4 crank in a 2.0 but it must be the same 6 bolt to 6 bolt ....7 bolt to 7 bolt ... ie early 7 bolt and early 7 bolt are different then later ones ... so you can not just throw a 2.4 crank into a 2.0 and be down the road. There are some good threads on here to use when building a stroker. If you have a 2.4 block I would build a 2.1 stroker using the 2.4 block and 2.0 crank ... just my opinon
