2G 4g63 rebuild kits advice
Dbo24
Oct 22, 2025
Nb, Texas
Just lost compression on #2 cylinder what is a good full rebuild kit for a good price for the turbo 4g63?
You should diagnose first why that specific cylinder doesn't have the compression and then plan. In case if it's valve related issue then you may not need to rebuild the entire engine. Then later you buy only what you need, that would save your money. Did you run a compression test and leakdown test?
Boroscope that cylinder and have a good look at the valves, as suggested.
