4g63 eagle rods
Gm68439
Mar 27, 2003
butler, Pennsylvania
I have recently got a set of 7 bolt ross pistons on a set of 6 bolt oem rods rods have been
opened up to accept them I didnt know that the pistons were 7 bolt because they were on the 6 bolt rods I know this because I removed them froma six bolt engine. I decoded the number on the pistons and they are for sure 7 bolt. I read that on the eagle rods seven bolts have to use 6 bolt bearings I was wondering if the rods would work on 6 bolt crank or can I have the brass bushing opened up to the right size to utilize these pistons
thanks
thanks
You pose your questions in such a way that I am somehwat confused.
Let me see if I can get this straight:
So, you say you have a 6 bolt engine (that you are rebuilding), and you pulled some rods and pistons out of another 6 bolt (a parts motor, so to speak?), and found out that it has 7 bolt ross pistons, on a set of OEM rods.
And you have your own Eagle rods, and you want to put those 7 bolt pistons on your brand new eagle rods, and put this all in your 6 bolt?
And you are curious if the Eagle Rods will work on a six bolt crank, and you also want to whether or not any modification needs to be done to make the rods work with the 7 bolt pistons?
Is this all that you are asking?
Where did you get the Eagle Rods? Are they made to fit the 4g63 6bolt? I would think that if you bought them for that engine, then yes they will work with your crankshaft. I mean, you bought them from a dealer, and told them what engine it was for, or not?
As far as the pistons working; 1G 6bolt rods have to be machined to accept 2g pistons.
Remember, the 1993 and 1994 are also a 7 bolt, but the are the same pistons that are found in 6 bolt engines (7.8:1 compression). 2G pistons (which are also 7 bolts), use an 8.5:1 compression ratio.
So you mean you have 2G pistons or not?
1G 6bolt rods have to be machined to accept 2g pistons. if you search 2g pistons in a 6 bolt, there is an image that shows the specs for the rods to accept the 2g pistons. I've seen it but I don't recall the specs. And yes, alot of people here do it.
It's one of the most popular engine building paths here.
When you put 1g rods with 2g pistons the rods have to be narrow. No machine work should have been done to the pistons at all. As far as using 6 bolt rod bearings, you use the 7 bolt rod bearings. There is no difference in 6 and 7 bolt cranks besides the number of holes that mount the flywheel.
just to make it simple you have to use 6 bolt bearings on both 7 bolt rods and 6bolt rods but from what I read you are wanting to put 7 bolt pistons on 6 bolt eagles and you can't do cause the size of the pin is different between the 7 bolt 22mm pin and the 6 bolt 21mm pin
You can do it they just have to be bored out 1mm. Also have to be narrowed a little bit. Very common practice on 1g motors looking for more compression.
