eagle rods
what do you mean right order, the instructions that came with them only tells me about lubing the bolts with the special lube. thanks
Yeah, I didn't realize there was any special order to them.
Also, on a side note, it would be a good idea to have them balanced.
I meant keep the caps with the right rod and don't flip the cap around. They have to be installed the exact way they came apart. Also to get them apart use a soft tool (not a hammer) The rod sets come balanced,there should be a paper with gram weights on it.
well i got a set I'm not usen brand new in box and there awsome rods, my friend is usin a set of eagle rods in his mr2.there great rods for those who have a 2g,and some what of an upgrade for 1g.I'm still using stock pistons and rods on my 1g,iv got another motor I'm going to build soon and my eagle rods and ross pistons will go in it.with eagle rods you get what u pay for damn good rods.
Eagle v.s Scat
Damn close to the same rod and Scat is cheaper
Look at the comparison
Fits Mitsubishi 4G63 Engines 3/8"" ARP 2000 Rod Bolts are used in all Eagle Rods for the 4G63. Rod Length 6 Bolt - 5.900"Rod Length 7 Bolt - 5.900" 1.771 6 Bolt Crank Pin 1.771 7 Bolt Crank Pin .826" 6 Bolt Piston Pin .865" 7 Bolt Piston Pin 1.117" 6 BoltBigEndWidth1.038" 7 Bolt Big End Width Total of $358.99
SCAT 6 Bolt 4G63 Rods are rated right out of the box to 600 + HP. They are great street strip rod that has been around now for going on two years. With a price of 319.00 and a quality equal to Eagle H-Beam's, they are an awesome alternative! All SCAT H-Beam rods are forged from 4340 chromemoly steel and have superior bend and twist ratings. They are fully magnafluxed, stressed relieved and X-Rayed from both ends. SCAT also provides an extra oiling provision hole on the top of the rod that is viewable in the picture allowing for better lubrication at high rpms. $318.99 could get cheaper
I hope you are going to check both ends of the rods for roundness and size before using them. Several people in the past including myself had to resize the rods because the were too big on the big end and you will more than likely need to enlarge the bushed end to fit the wrist pins like they are supposed to.
