August578
5+ Year Contributor
101
28
Jun 15, 2021
Eastvale, California
Hi, I am currently doing a 4g64 turbo conversion and know that the injectors stock are high impedance. I also know that the 63 uses a resistor box for the fuel injector to make them low imp. So I found these high Impedance 450cc injectors and wondered if I can just plug and play them instead of having to wire a resistor box. Thanks. P.S I am doing this for the ease in the event I need to revert for Cali Emissions, then obv swap back.
Stock turbo cars use LOW impedance injectors, the resistor pack makes them look like high impedance injectors to the ecu, the high impedance injectors are more expensive so some car manufacturers used the low impedance with injector resistor box method to get around the cost of high impedance injectors, those should work if they are indeed high impedance and they meet the length requirements.
