420a starting problems
GP420a
May 18, 2020
Kansas City, Missouri
I bought a 420a manual 98 Talon that can be started with button or key a few months ago. Started and drove fine since i bought it. Drove it hard very briefly and after parking the car, I went to start it and it would click but not turn over. Started and ran fine by pushing the car. The next day put a bunch of new parts on the car, including a new starter. Still wouldnt start by button or key. With all the new parts the car runs really well, but now bounces back and fourth between being able to start it by key or button, only key, only button, and now currently back to not at all unless i push it.
Besides rust and sloppy wiring, the car is clean and even cleaner internally. The wiring to the push button start doesn't look bad and isnt loose. A lot of work and nice parts were put in by the previous owner. Im guessing the starting issue is something the previous owner delt with, because of the push button being installed. I'm unsure and was hoping someone may have some idea as to what the issue could be.
'Jerry you have to see the baby' I mean the grounds, check your grounds, make sure they are tight, that will be the problem for sure, or a relay LOL.
sloppy wiring
Right there, that is your answer. So many people throw all sorts of aftermarket systems in these cars, and the cars simply don't like it. The push start setup is the probable cause, and not wired in properly. If you're ok with just having the oem key starting your car, remove the push start system.
