91-talon-tsi
- 52
- 1
- Mar 29, 2010
Ada,
Oklahoma
Ok, so I replaced my timing belt, and water pump and converted from the hydraulic tensioner to the mechanical tensioner. I went to put everything back together and the harmonic balancer (AKA crankshaft pulley) bolt would not seat fully, but the crank tried turning while I was tightening the bolt.
A friend suggested using vise grips to clamp the cam gears together to keep the engine from turning. This worked until the crank bolt started getting hard to turn, then I hear a "click" and I look up and lo and behold the timing marks on the cam gears are off by 3 teeth on the intake cam !
What are the odds that any valves were bent ? What should I do now ? I start a new job in a week and need reliable transportation !
Anyone have any insight to this ? I trust that you guys know the answer to this better than anyone else ! I had an offer from someone to buy my eclipse for $1000 and I'm considering selling it because I'm tired of messing with it. It's such a pain to take that side motor mount and everything out just to get to the timing belt.
Not to mention having to rent a special puller to pull the harmonic balancer only to take it back and rent a harmonic balancer installer kit (which by the way doesn't fit the 420a harmonic balancer) This car is a pain to work on ! I ended up pounding the harmonic balancer back on with a block of wood and a hammer.
) - DSM
