420a relay help
TimF
821
7
Mar 14, 2011
Aurora, Illinois
Hello guys I just need some help finishing up rewiring my ESi. The car was originally had a custom harness for a Haltech ECU but I am reverting the car back to stock to get it running again and there was no way that harness was going to work with a stock ECU.
I was able to snag one cheap from the local junkyard but they only had auto 420a cars (mine is manual). Everything still connected fine other than the pigtails for the auto trans which I know I don't need. The only other issues is I have 3 plugs that go to relays and only 2 relays on my fire wall + 2 more aftermarket ones that where used when the old harness was in.
I was wondering does it matter what plug goes to what relay or if they are the same and is there just one extra because it came off a auto and one wont be used?
The aftermarket Bosch ones can be seen in the picture with the plugs
The 3 OEM relays are
: (starting with the one closest to the brake fluid res.)
- fuel pump relay
- ASD relay
- eATX relay
The relays are basically the same but the plugs may be slightly different.
The plug for the fuel pump relay is black and should have a
(Black/white) (red/black) (white/red) and a (black/blue) wire.
The ASD plug should be grey
Here is a copy of the electrical manual
http://www.mediafire.com/download/6v705mm1dzx/97-99Electrical.pdf
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
