420A going turbo Vacum lines help needed
BeClipse
39
May 29, 2004
alexandria, Virginia
hi I have browsed a lot thru the threads to find out where the vacum lines tap into. But I'm not clea at all. Some people say EGR I have no idea where that is. I I have 4 lines I have to hook up
1. boost gauge
2. Cartech FMU
3. BOV
4. external waste gate
So I would really like to use twp sourses I was thinking that one would be the one on top of the throttle for the BOV and Waste gate. So I need another one for fmu and bost gauge.
I really need some help. If you can provide me some pics i'd really appreciate it.
ok... you also need some kind of boost controller, if you are running a manual boost controller you would take the vaccum from the wastgate and run that too the boost controller, then from the other side of the boost controller run that to vaccum... from the top of the throttle body, thats what i used, just T off the vaccum line there, the boost controller line shouldn't have any other T's it should be direct to vaccum as you can, for everything else you need to hook up, look at the front right side of your engine, there will be a small black ball almost, this is the egr, here is where you can tap in for all other vaccum lines, there is an arrow on it that says VAC and points to an outlet, that is the vaccum you could use. i tryed to post a pic but this site woun't let me, if you want to see waht i am talking about email me and i will email you back pic....
