Kevin Jewer
DSM Wiseman
- 1,486
- 349
- Jul 25, 2002
LaRue,
Ohio
After running 8.39 on a Forced Performance HD3582 (their low budget 35R variant) at the shootout last year, I decided to try some other turbos in this size range. Over the winter I switched to an older FP 3586HTA that I borrowed from a friend. That went 5.12 and 7.99 for ET with a 100 shot in Tulsa, which I was pretty happy with. After running that for a while through the spring and summer I decided to try a Forced Performance/Xona Rotor 62mm and see how much better that does. Pretty quickly it ran a 4.96 at 137 in the eighth at ORP in Missouri . I haven't run it quarter mile yet but it should be 7.80s or better on a 4.96. Back pressure is really low on the UHF turbine wheel, emap:imap is around 1.2:1 at full tilt. I then took it to a local dyno day and ran it on a Mainline Pro Hub 3000. It made 813 hp with no nitrous, and 948 hp with the 100 shot. I've learned a lot this year messing with the small turbos, as I always do. Always a good time. Car is ~2400 lbs race weight in this trim. I'm looking forward to running it this way at the Shootout to see what it will do quarter mile in decent air.
