2nd Rear Main Seal LEAKING!
yoyo13131
75
Feb 5, 2010
Santa Clara, California
1992 Eclipse, 2.0 FWD non-turbo 6-bolt crank.
Does anyone know why my rear main seal keeps leaking?
Fully rebuilt motor..
1st Seal: Replaced the main seal, u-shape gasket and placed the oil separator in with the hole to the bottom from the get go. leaked like a sive the first time, went to replace it and discovered the seal destroyed itself after 71 miles.
(Transmission seals are brand new, aren't leaking, same with slave cylinder. Replaced PCV too)
2nd seal: This time checked the flywheel for any scratches, nothing it's really smooth all around. I used a Felpro seal and U-gasket, again used B-RTV and separator hole at the bottom. It's not leaking as bad but leaking still...
Did some research on here and found this from a wise-man
"You don't need the specialty tool shown in the FSM to install the new seal. Make sure it's flat and gently tap it in with hammer. It needs to be just a hair *above* flush. If you pound it in flush, it will leak on you. "
After reading this I think I might of realized my problem, BOTH times I've replaced my real main seal I've purposely made sure the seal is COMPLETELY flush!
Ultimate Question, will making it flush really make the seal leak?!
You answered you own question.. Listen to the wise man. They don't call him WISE for nothing.. :D
I just put spit around mine, gasket, shove it over the crank, and gently press on and bolt it. Done, dont touch the seal after you slide it on. Just touque the bolts.
Are you sure didnt forget a big oil galley in the block? on tranny side?
I see no basis for the 'flush' theory. I've always put mine in flush and never had a problem. When you take it apart next time find out where specifically it's leaking, the seal itself or around the seal housing.
Take a good look at your crank sealing surface, the 6 bolt I have apart right now has a pretty worn crank surface. Apparently it's such a big problem with DSMs they make a repair sleeve...
Chrysler & Mitsubishi Rear Crank Seal Repair Sleeve
If you for any reason forgot this hole, this could be an issue.
where the seal rides on the crank can groove over the miles, the just above flush could be to put the seal lip in a new spot.
also the crank repair sleeve can be used to cove the lip seal groove.
Thanks for all the reply's, but I've already JB welded AND red RTV'd my oil galley hole (plus Teflon tape) and it's not leaking at all... my engines completely rebuilt, first seal was leaking pretty bad at 71 miles, and now my second seal is now at 250 miles and its leaking again....
Also, this "repair" sleeve will fix the problem if my crank has some scratches but will create another problem leaking between the crank and repair sleeve wont it? Wouldn't only a PRESS fit repair sleeve not leak?
Anyone used this repair sleeve with success?
  • Wanted 6 bolt NT water pipe
    • chrisman287
