2nd gear grinding problem..
18Ace18
107
Apr 24, 2010
Hialeah/Miami, Florida
Lately my 2nd gear has been grinding, i checked the clutch fluid and it was empty :ohdamn: so i guessed it was cus of that, i filled it up and it still grinded.
Today i noticed that the master is leaking fluid, would a bad master cause the grinding? :confused:
It could cause the clutch to not be able to disengage all the way making it hard to get into gear. Is it only second gear that is hard to get into? If so it could be your syncros in the transmission. Also, are you sure the transmission is full?
