420A 2gNT How do I install shifter bushings (under hood)
Stizzydrew
193
74
Nov 11, 2021
Los Angles, California
This may probably be a silly question to some of you but I have under hood shifter bushing and j have seen that one is under the battery and under the intake. Just to be 100% sure.. can someone tell me exactly what to do? I don’t wanna take something off and mess something up. This is my daily . How long should this process take ? If someone can help me I would really appreciate it.
Here are how the bushings look.
Shouldn't take more than 10-15 minutes. Pull the cotter pins and the whole shift cable assembly comes off the shifter arms on the trans. Your old bushing are probably rotting so removal from the cable is very easy. Install the new ones and install the new cotter pins. If you have a pair of long needle nose pliers and skinny fingers it will be simple and nothing removed. If not then remove the intake pipe for better access. I'm pretty sure I didn't remove anything from my car to gain access but the intake may have been off at the time. The best access would be without the battery tray in the way. But it's not worth the extra time of removing it, just work around.
At some point somebody tried to use a washer to shim my old bushings. LOL
New bushing installed
Thank you for telling me how to do it. It definitely didn’t take me 10-15 mins because it was my first time but I definitely installed them. I removed my battery bc it made it easier for me. Here some pics of the new and old ones.
Also turns out I need a new negative battery cap. Lol you fix one thing on these cars and something else pops up :ohdamn:😂
