2G 2g with a 1g engine
Jonnystg
Apr 28, 2021
LOS FRESNOS, Texas
I just bought a 2g eclipse but it seems to have a 1g 4g63 engine question here is, despite the fact it has the 1g engine do i still put 2g parts such as alternator and other components that go attached to the engine?
everything you need to know about a 6 bolt swap which you have. i looked in google found in second.
Thank you
I found out its a 7 bolt i had gotten a 6 bolt clutch kit and had to return it because it didnt fit. what it does have is an eci-multi air intake manifold from the 1g, (is there,)would there be any issue or inconvenience for it to have it?
Nicee, is there any lines i have to cancel because its on the 7 bolt?
Well, just a curious question. I saw some lines that were topped with bolts so i was curious if i had to cancel any lines comming from the air intake manifold
Those were canceled and i was wondering if i had to cancel any more
There is no six bolt clutch kit. There IS a six bolt flywheel. Clutches are all the same 90-99.
