2g Stall
Xplizitgsx99
Apr 14, 2008
Nanuet, New York
I have a funny stalling problem and need help figuring this bad boy out. My 2g Gsx is stalling when it idles down.. The needle just drops and the car stalls out. This happens when im driving. If the car is in neutral i can hit the gas al I want and it wont stall. Any ideas?
Well, the venting is probably a big cause of your stalling issue (I'm assuming you're not venting correctly by using a GM MAF or speed density setup). Recirculate the bov and then see if it tries to stall out on you. And you should do a boost leak test. If you don't know how, do a search. You'll need to build a tester and have a compressor or air tank.
Yea sounds like the exact same thing I had before I spun a bearing. Boost leak test and recirc. that should do the trick. If not just keep asking
