energy supension kit in stall 2g ?
philpuc269
Sep 15, 2007
lexington, Kentucky
I am tring to remove the bushing from my awd. I have a ball joint press but none of the attachments seem to be the rite size. if anyone has done this please tell me how you got the bushings removed.
Stick it in the ground and light it like a tiki torch. After the rubber is gone, carefully cut through the bushing shell. It's best to cut in a direction parallel to the arm so as not to weaken the outer ear if you cut too far. Once you cut the shell it will practically fall out.
