Resolved 2g Spyder GST doesn’t want to idle
Tsuri
33
Dec 14, 2022
North Chesterfield, Virginia
Before I start this thread I want to say that it is not the most thorough description because I can not find the problem even if my life depended on it.
Alright so I’ve been having this issue with my car where it just won’t idle most of the time. The car will start up fine then it will stall out even after warming up. The car drives perfectly fine but everytime I have to stop the car will stall out once it tries to idle.
I’ll post a video below and you can see me actively trying to keep the car alive. I just wanted to know if anyone else has had this problem and what the fix was for your car. (Don’t mind the belt I know it needs to be replaced)
Solution
I found out the issue to be something with my wiring, the idle...
I found out the issue to be something with my wiring, the idle sounding like cams and car not idling is because the car is cutting on and off, not sure why I didn’t assume anything with wiring before LOL.
Solution
