spyderdrifter
- 5,425
- 855
- Jul 11, 2009
Somewhere in,
Colorado
Are 2G rear knuckle/spindles the same between FWD & AWD.
You would not of, the Fwd cannot be used on an Awd because the hub hole is too small and wont allow the awd besring to mount! So an awd can be used on a fwd IF only IF the knuckles and bearings are swapped to,pretty sure I swiped a set of rear knuckles out of a super clean 99 OZ rally edition .......way back........for one of my GSXs
dont remember running into anything that could not be worked around. its been a lot of years though
I wanna say you can just knock the dust cap out and bolt an AWD bearing assembly in.
Does anyone know if I swap 97-99 rear knuckles into my 95 fax, will all other parts work? Or will I need 97+ trailing arms or swaybar?
