Please Support Kiggly Racing
Street Build street build
Ownership Status
Currently Own
Mitsubishi Eclipse GST
Turbo Type
16g
Drivetrain
AWD
Build Type
  1. Street
punishment racing fmic kit, fic 1200 injectors fuel lab afpr, walbro 450 with rewire, dsmlink v3. AEM 3.5 digital boost guage, innovate Lc-2 WB, hallman MBC, megan downpipe, 2.5 his ti carbon catback, evo3 big 16g, injen intake mishimoto slim dual fan shroud, greddy BOV
Mods-EMS & Logging
Dsmlink v3
Mods-Drivetrain
Act 2600 street clutch and act flywheel arp flywheel bolts, stm "under hood" shifter bushings, energy suspension shifter base bushing kit, prothane driveshaft bushings, volk solid diff bushings
Tein flex coilovers, energy suspension (or prothane cant remember it's the bushings that are two piece) bushings, volk solid subframe bushings, DC rear strut brace
Background
got the car in early 2018 completely stock, immediately got dsmlink and gauges, then did timing belt/waterpump, and bolt ons then fuelpump afpr and injectors, car is now being painted and 97-99 front end conversion
8/19 Got everything for my AWD swap (I think), cant wait to get started on that. I'll be pulling the engine and doing a refresh/rebuild this winter. The plan was to drive the car as is this whole summer but I'm on a roll and am having a lot of fun working on it and learning as much as I can. So I'll probably be starting the swap earlier even though I only got a couple months to drive it haha
5/20 awd swap is almost done, replaced all bushings in the suspension with poly, awd gastank mounted with wally 450 wired in for e85 next year, stm solid driveshaft carrier bushings, motor is out with fresh timing belt job with gates belts and OEM pulleys/tensioner and water pump, new poly engine mount inserts differential and subframe bushings got volk solid replacements, got some tein coilovers, and all the little things like new drain plugs, breathers for the trans and diff, crush washers for everything like the water lines for my evo3 big 16g, act clutch and flywheel with arp bolts. Should be rolling in a few weeks as I'm only able to work in the garage one night a week replaced a few busted electrical connections with ones from donor car harness, DC rear strut brace
dsmlivesmatter
More in 2G DSM
Share this Vehicle
