Timechg
- 229
- 4
- Oct 7, 2004
Iowa City,
Iowa
There are a ton of threads on which head flows better and whatnot, but that is not my question. I have a 2g head that is going onto 6 bolt block (2g head has already been prepped for larger studs etc.).
The question is what water pipe to use if I am putting a 14b on. I saw one thread that stated I could put a 1g thermostat housing on with a 1g pipe (with modified or 1g lower radiator hose) or other threads saying that I need to block off coolant lines etc, and another thread saying they were going to tap a hole to the coolant passage in the block (I want to avoid this).
Do any of you guys have any experience with this? Also can I still use a modified 2g oil drain tube, or do I need a 1g oil drain tube for the 14b turbo?
Thanks in advance!
Thanks in advance!
