TurboAnything
- 701
- 12
- Jun 6, 2004
Carol Stream,
Illinois
The 2g head is a more modern design it has raised ports to direct the airflow down on the valve and speed up velocity. The 1g head is a crude way to get a lot of air to the valves but the velocity is reduced. Think about it i do not know of any modern engines that use intake ports as big as a 1g head. I would say if you had a choice go with a 2g head the raised port design is better for any car up to 600hp. You will get better atomization of the fuel with increased velocity and i do not think the smaller port would restrict airflow to the point of power loss. Raising a port is a common answer for freshening up an old head design. you just want to make the airflow come down on the valve instead of coming in from the side and making a 90 degree turn down to enter the combustion chamber.
