2g fan wiring (stock fans)
2GturboTALON
607
6
Nov 26, 2002
St. Peters, Missouri
I am having a tough time finding out what each wire does on the engine wiring harness side for stock fans. I know so far on the fan side these are the controls but i need to know which wire these correspond with on the harness side connector. Thank you in advance
Fan side connector colors :
Passenger (radiator)
Lo +=white/black (white with black stripe)
Lo - =black
Hi + = white/blue (white with blue stripe)
Hi - =blue/green (blue with green stripe)
Driver (a/c)
Lo += blue
Lo - =blue/black ( blue with black stripe)
Hi += blue / white (blue with white stripe)
Hi - = blue/ green (blue with green stripe)
We are getting closer. The colors I posted were the ecu side not the fan side. So lets clear this up and go on. This gives me a decent start. Now i just need to figure out the fan side HI and LO + and -. Does it matter which negative you connect to or will they only turn on connected to the right negative ?
Passenger fan
Fan side ..... ECU side
Yellow (-)(?) .... black (-) (lo)
Black (-) (?).... blue/green (-) (Hi)
Blue (+) (?).... white/black (+) (lo)
green (+)(?) .... white/blue (+) (Hi)
Driver fan
blue/black (+)(?) .... blue/white (+) (Hi)
blue (+)(?) .... blue (+) (Lo)
black (-)(?) .... black (-) (Hi)
black/white (-)(?) .... blue/black (-) (Lo)
