Resolved 2G Bad ECU?
krypt keeper
May 30, 2012
cape coral, Florida
I had my mechanic check out my car and he said my ecu is bad i have search the forums have not had much luck I don't have a lot of cash does anybody have any suggestions on where to get one or have mine rebuilt thank:confused:
Oh yeah he said i have a eprom ecu
To begin with, what problems are you having with your car? We don't really have any background information to determine if your mechanic (1) knows exactly what he is doing and (2) if it could really be an ECU problem.
I agree with pulling out the ECU, opening up the case and taking some good high definition pictures for others to evaluate.
If it ISN'T an ECU problem...you could sell that ECU to another member or trade for a regular non-eprom ECU to front your new repair bill....:sneaky:
Okay I'll take some pictures of the computer mechanic says that there its not grounding out properly which is the problem and is putting up the idle air control motor fault code and the mdp sensor fault code and the idols is ruff sometimes thanks for the help
One more thing, don't i want the eprom ecu so i can use a plug and play ecmlink or something like it? i cant afford the aim stand alone im balling on a budget
Have him pin out the ECU then to see if it's getting a proper ground signal.
http://www.dsmlink.com/images/forums/2GECUPinout.pdf
Here are some common ECU damage areas to check out. If the ISC is having issues it could either be the driver (info/pictures can be found in the first link) or the ISC itself.
http://www.dsmlink.com/wiki/ecurepairhome
http://www.dsmtuners.com/forums/articles-tuning-ecu/386663-dsm-isc-motor-testing-replacement.html
According to your profile you have the stock engine. Just want to verify that's true and you don't happen to have a 6 bolt swap.
Yes my car is all stock my goal is to build it out to 500hp to the wheels nothing crazy and im not rushing i just started all my maintenance so i know the car is in good shape before i get some mods done but wright now its my dd so i can only do so much myself i will get those pic up soon thanks again guys for all your help and any suggestions appreciated
Thanks for all your help, my ecu was fine just a bare spot in the ground wire. Thanks again as always all your suggestions appreciated
Solution
