knochgoon24
DSM Wiseman
- 6,135
- 98
- Jan 29, 2008
Troy,
Michigan
I finally go a job lined up for the summer that will give me some extra spending $$$. I've been wanting to do this for the last year, and now I think I'll finally have the chance.
Goal:
About 350whp. Auto AWD. This is my DD, so I want to keep some low end torque.
I'm trying to keep this a budget build using used parts where I can. I'm a college student and money is tight.
Background:
Current engine is a replacement the the previous owner had installed 85k miles ago. Unknown mileage on donor engine.
The transmission was rebuilt 65k miles ago. It has all the really bad shift flares. I even have the P1750 CEL.
About 8k on timing belt components.
************CURRENT MODS************
NXS MBC @ 15psi
Hard intake pipe
CXRacing FMIC 29x8x3.5
2.5" IC Pipe Kit
Custom Full 3" Turbo-back Exhaust
All new hoses, gaskets, and belts
Tubular o2 housing
HKS SSQV
NGK BPR7ES gapped to .028"
Stock Fuel Pump Rewired
Stock 450cc Injectors
Stock FPR
BSE
Boost Gauge
Oil Pressure Gauge
LC-1
EvoScan
SAFC 2
**********PLANNED UPGRADES**********
TURBO
HY35 (9cm^2 T3 housing, fed from OFH w/ Restrictor)
-Buy it off Ebay & rebuild
EXHAUST
Custom Tubular Manifold (friend who builds hot rods is going to help me out)
Custom O2 Housing (same friend...)
Tial 38mm External WG Recirc'ed
TUNING
3" GM MAF
Maf-T
Evo 8 Ecu
EvoScan/EvoFlash
FUEL
Walbro 255hp
680cc Injectors
AFPR
ENGINE
Hopefully it just needs honed.
New Rings
1g Rods? Maybe...
New Water Pump
New Front Case
BSE
New Timing Belt (Oil got on belt)
Saturn Alternator Swap
Evo OFH w/ Oil Cooler
ALC Tri-Metal Bearings
APR Head Studs
ARP Rod Bolts
HEAD
264/264 or 272/272?
New SS valves, seals, and guides
3g Lifters
TRANSMISSION
IPT Shift Kit
IPT Rebuild or End Clutches (depends on $$$)
OTHER
Battery Relocation
2 - 12" Slimline fans
Aluminum Radiator
Now, I have a few questions.
1)I don't know what rods to get. 1g Rods are fine for the power I plan to run, but are there any others I should consider?
2)Should I go 264/264, 264/272, or 272/272 with the cams? This will only occasionally see the track and it is an automatic.
3)Would a Walbro 190hp work? I'd rather not have the whine, but I've never been in a car with a 255 to hear it, so I don't know.
4)I plan on running the Evo 8 Ecu. Should I get the Evo 8 Maf-T? It's all adjustable with ECUFlash, but I'm not sure which to get to simplify things.
5)When it comes to injectors, I should be fine with anything larger than 550s, correct? So I can go with a good deal on a used set larger than that?
If anyone has anything critiques on this, feel free. This should be feasible with about $2000, right, since I'm fine buying used? I can do all the work, except the machining, myself.
Goal:
Background:
NXS MBC @ 15psi
Hard intake pipe
2.5" IC Pipe Kit
Tubular o2 housing
HKS SSQV
Stock FPR
BSE
Boost Gauge
Oil Pressure Gauge
LC-1
EvoScan
SAFC 2
TURBO
EXHAUST
TUNING
3" GM MAF
Maf-T
Evo 8 Ecu
EvoScan/EvoFlash
FUEL
Walbro 255hp
680cc Injectors
AFPR
ENGINE
New Rings
1g Rods? Maybe...
New Water Pump
New Front Case
BSE
APR Head Studs
ARP Rod Bolts
HEAD
264/264 or 272/272?
3g Lifters
TRANSMISSION
IPT Shift Kit
OTHER
Battery Relocation
Aluminum Radiator
Btw, 190 would be fine I think.
I want to try the hy35 because you don't hear of too many DSMs running one. People say the hx35 spools just a bit later than a 16g by using the BEP housing (.55 a/r). The hy35 housing is a bit smaller than that with a .48 a/r.
despite having a smaller turbine wheel and housing than hx35.
