2.3 part #s
jazzyjay
215
Mar 27, 2003
I want to start this tread for the purpose of having a place where some one could go to get part numbers for their 2.3 build. Please don't post this brand is better than the other just part #s.
STROKER PISTONS MAKER/PART#/6 or 7 bolt
JE/JE-202194/6
JE/JE-202192/7
MAHLE/86.0mm BORE 9.5:1-Dish/Inverted Dome -23cc- Part Number MIT130385I23/6
MAHLE/85.5mm BORE 9.5:1-Dish/Inverted Dome -23cc- Part Number EVO130366I23/7
CP PISTONS/CB-SC7205/6
CP PISTONS/CB-SC7206/7
WIESCO/WI-K571M86/?
ROSS/99869/6
ROSS/99871/7
Manley/607005-4/6
Manley/608005-4/7
CRANK
89-91 Sonata 2.4
Eagle 100mm
? Mighty Max
Eagle 4340 Forged Steel Cranks
6 Bolts;
88mm Part # - 2034655900a6
94mm Part # - 2037005900a6
100mm Part # - 2439375900a6
7 Bolts;
88mm Part # - 2034655900b7
94mm Part # - 2037005900b7
100mm Part # - 2039375900b7
All to be used with the stock 2.0 rod length of 5.900
Did anyone figure out if the G64B crank(found in the Mighty Max and Expo), was the same as 6 bolt crank found in the G4CS.
Arias #3420350 (individual p/n) set# 361468 (includes pins, button style locks and ring set)
8.5:1CR .020"/85.5mm over 2.3L (6-bolt)
Features:
Dispalcement: 140.13 -2297cc
Stroke: 3.937 100mm
rod length: 5.906
Comp Height: 1.135 -28.82mm
Pin Dia: .827 -21.01mm
Top Grove: .060 -1.5mm
2nd Groove: .060 -1.5mm
Oil Groove: .158 -4.0mm
piston weight: 306g
piston-to-wall clearance: .0040 -.10mm (if coated, subtract .002")
NOTE: Will NOT work with Scat rods (Scat's small end is too thick to fit inbetween the Arias piston's wrist pin bosses). PM me for specifics.
