1G Wheels on a 2G
Status
Not open for further replies.
ETalon95
232
Sep 11, 2004
Whitehall, Pennsylvania
Will the first gen GSX wheels fit on a 2nd gen GSX. I was offered 4 of them for $50 to use for the winter.
I'm pretty sure they will because the got the same bolt pattern. Your ride might seem a little lower than usual though since the the rim size is smaller.
yes they will clear everything. they are the same standard 16 inch alloys that came on 2g eclipses only with a different swirl pattern. everything should match up good. go for it.
They will for sure fit because one of my buddies did it. He needed some winter tires and wheels so I had a 1g set laying around and they bolted right up.
Status
