Resolved 1G Unusual timing belt wear
Buffalobeans
Dec 10, 2009
Salt lake city, Utah
K where do I start so I have a 93 talon nt that I swaped a 6 bolt into everything was going great, 700 miles later I get a noise from the timing belt side (driver). It sounds like a wobley pulley or something off balance, rubbing on the timing belt cover or in it? So I check the belt (new) and it already has wear on it on every 4th tooth there is a little groove/cut out/indention, it's really small close to 1mm in half moon shapes.
When the motors running the timing belt doesn't move. It sounded just like how everyone describes a crank pulley/harmonic balancer, so I removed all belts but timing and balance belt. I also removed the crank pulley which didn't separate into two pieces it looked good. It also made the same noise with all of them off so I naturally ruled it out.
Prior to the noise I noticed that my oil dumbie light would come on when motor was hot and would go away temporarally if you increased idle I'm just hoping it's all being caused by the same thing
Solution
So it turned out it wasn't the tensioner and a burr would be inconstsant
but me checking the tensioner helped me stumble upon the entire balence belt was shreaded and that would answer my oil dumby light, and off balence engine
Yes it has come off when i droped the motor in
I'll upload pics later today of the timing wear
make sure you didn't mix up your 2 short pan bolts with long ones. My guess that's yer problem.
SEARCH FOR " timing belt falling apart"
^^ exactly. If the pan came off and the 2 short bolts got mixed up with the rest when it was put back on then it's very possible that one one of the long bolts is protruding far enough to make contact with the belt. However, when that happened to me the wear mark was very even along the length of the belt None of this skipping 4 teeth in between.
A picture will help.
If you have grooves in the teeth of the belt then i'd check the teeth on all of the gears. you might find a burr or maybe something was bouncing around inside the timing cover.
I could have mixed them up but wouldn't that have even wear all the way around the belt and could my noise be interlinked?
Ok so here is a photo look very close to the motor side of the timing belt and you'll notice a mark on the edge of the belt every 4 teeth
Could it be caused by the balence shaft?
not your pan bolts if that's what it is. guess i didn't understand the situation before the pics. pictures do tell 1000 words. sorry for the confusion
The only thing I can think of that would leave a mark on the outside of the timing belt is the tensioner. It's also about the right diameter to leave a mark every 4 teeth.
Solution
