dwb
- 1,571
- 1,089
- Sep 9, 2021
Broomfield,
Colorado
I'm needing to do some work to the rear subframe/suspension/axles/etc. of my 91 TSI AWD. I've never done any work back there besides brakes and rear diff fluid. Something is causing alignment issues and when I hit a hard bump, I feel the backend slightly skip to the left. I want to rebuild what I can and then have it professionally aligned after.
I don't think I'm dealing with much rust but I know my shocks, wheel bearings, bushings, axle boots, and drive shaft carrier bearings all need replaced. I already have the Energy Suspension Rear End Control Arm Bushing Set and 1 new OEM carrier bearing. I still need to source replacement shocks, wheel bearings, axle boots, and another carrier bearing.
What else should I be looking to replace "while I'm in there?" Subframe bushings? Camber adjustment bolts? Stabilizer links? Can the ball joints be replaced? I'm just aiming to get it back to how it was stock so I can have a successful alignment.
Also looking for any write-ups for 1g rear bushings, struts, wheel bearings, or whatever might be helpful for this project.
