Dstarperformance01
- 880
- 174
- Mar 5, 2016
Mustang,
Oklahoma
Can a 1g na(1.8 donor car) cluster work in the turbo models? My main concern/interest is the tach functioning properly
I have it installed but haven’t tested it due to being busy with clients cars and getting fuel pump back from magnafuelThough I'm not positive, I do not believe the tach would work. The 1.8L models have a unique tachometer part number, they are scaled differently (8k limit versus the 9k limit of the 2.0L models), and the signals are sourced and filtered differently. There's just not enough going for it to assume that it would work.
Would love to hear from someone who's actually tried it if there's anyone out there who has.
Good stuff. It's easy enough to change out and try, not the end of the world if you give it a go and it doesn't do what you want.
"So you're saying there's a chance!"
That’s encouraging but I am running out dated AEM V1. I follow his channel and didn’t even notice that thank you sirJoe Bucci runs a non turbo cluster in his fwd and his tach works but he’s on a different ems.
No problem. Hope it works out. Good news is they’re fairly cheap. Let us know if it works.That’s encouraging but I am running out dated AEM V1. I follow his channel and didn’t even notice that thank you sir
Definitely will let everyone know the outcomeNo problem. Hope it works out. Good news is they’re fairly cheap. Let us know if it works.
Thank you for the encouragement as it’s frustrating. It Needs replaced or rebuilt. I want to go bigger but that will require a different ecu and tune along with turbo upgradeThanks for the update. Hopefully you get the turbo situation sorted out.
