CrackedDSM
- 5,833
- 5,730
- Dec 17, 2009
Pensacola,
Florida
I am at my wits end with this car. Details of car in build thread.
Issue: Car will not start. Has spark, has fuel pressure to rail. Does not have injector pulses. Activating injectors in link does nothing. Injectors are receiving voltage, just not completing the circuit or whatever. When I test the injector clip while trying to start (or when activating via ECMLink), it won't activate the test light.
TPS is tested and working, seeing proper voltage and signal. Nothing is unplugged that I can visibly see, ECU was taken out and no burned drivers or leaky caps were found. ECMLink connects to the ECU just peachy, and no codes are found or stored.
Relevant detail: The water temp gauge via the gauge cluster has not worked since I got this car. Now suddenly it's reading 1/4 of the way when I turn the ignition ON, and then drops down to zero when turning ignition off.
IDK what to do, or everything that controls injector function. I didn't see any wires chewed or missing when I crawled under the dashboard on the drivers side, but if you know more, by all means.
This car started and ran 24 hours ago. Now it's dead.
