No start issue
Dewayne Waldron
371
Apr 5, 2009
Salem, Virginia
Its been about 2 weeks since I last started the dsm. Started fine with no problem. This evening I tried to start her up and nothing. Started checking around and figured out im not getting spark and also there is no injector pulse. I'm thinking ecu again but can you guys give me some ideas on anything else it could be. Absolutely everything on the engine has been replaced except for the coil pack but that wouldnt cause me to not have an injector pulse right. I need some help with this one. Might be selling it and dont want to just buy an ecu not knowing if thats truly the issue.
Its crank no start. No fuel. No spark. I Checked the cas and im not getting s reading on anything under the hood. Im getting 12 volts to everything but im not getting a reading coming out of anything. What the hell is the ckp?
Get a multimiter and put the negativeof the meter in the possitive terminal of the battery and possitive of the meter in the red wire of the cas and if the resistance is high you have a short. Use the search button if you still dont understand. Good luck
