Resolved 1G How to test Radiator Fan?
SnowmanFD
142
8
Dec 11, 2021
North Seattle, Washington
My car is overheating when its sitting still. (See previous posting for more details) The first thing i would like to check is if the fan even works.
Im 95% shure its an aftermarket fan because of a few reasons
1. Theres only 1 fan instead of 2
2. Its very "slim" (think its a ebay slim fan)
3. There's a wire going from a switch (aftermarket) in the interior that ends "near" the wiring for the fan (doesn't connect)
4. There is a circular metal fuse insted of a black square like all the others
Solution
I could watch the video with better quality. Looks like it's using the stock wiring. There are 2 wires that are connected to the radiator fan (the wires in the pic below). Check the blue with red line wire for 12v (the blue/black is ground) while the key position ON and the short wire inserted. If you have 12v on that wire, the fan is dead. If you don't have 12v, the fuse or relay is blown or bad wiring in somewhere.
Also you can just unplug the radiator fan and connect the 2 wires from the fan to battery directly. If the fan doesn't spin, the fan is dead.
The fuse is in the small box that is attached on the battery + terminal. (Should be a pink one 30A)
First off, is this the...
Is there any advantage or disadvantage to not removing it?
This is what the clip on the back side looks like.
Minimal. Less airflow through the radiator. Only other thing I can think of is it being in the way of the new fan. See if you can unscrew it. Maybe it’s not zip tie style.
