2G 1G Head, Intake, TB on 2g 7 bolt -- is it possible?
patman
5+ Year Contributor
107
62
Oct 19, 2017
Budapest, Europe
Hi
I have a EU spec 2g with a stock 2g 7bolt N/A 4G63 (which basically acts as a 4G64). I have the found a good deal on a 1G valve cover+head+intake+throttle body combo (all stock). I wanted to change the valve cover for a long time now, because it is cracked. The quiestion is, is this setup compatibile with a 7bolt 4g63? Does it come with any gains? If it just messes up my timing or idle, and nothing useful I will only go for the valve cover.
If your main interest is a swapped valve cover, you can do that without swapping the head, etc (assuming the n/a 4G63 you guys got was DOHC).
I don't know enough about the N/A 4G63 to say if the heads are easily swappable. There might be difference in deck heights or something that'd give you issues. Someone else will chime in.
It is a DOHC, itt looks identical to the 4G63T I think the only difference is the compression ratio (apart from the turbo ).
I can buy the 1G cylinder head with the intake, so the whole top part of the engine would be swapped, still I'm worried about timing, I dont know if the 1g timing is identical to the 2g
That's what I was asking, I just saw some 2g people here with 1g intake in their cars and I got corious why could they do that. But I guess they did a whole engine swap :)
With respect to turbocharged 4G63s, the heads can be interchanged with some machinework. The head studs are different diameters between the generations and so the holes in the head need to be enlarged for the head studs to fit through.
As far as the reason to do the swap, it mostly comes down to port size. Many people jumped to put a 1G head on a 2G block because the ports are much larger on the earlier head and manifold and the thinking was that the 1G head would flow better because of this. The reality isn't that clear cut because the flow through the two heads isn't as different as previously thought. The important thing for you to keep in mind, being naturally aspirated, is that Mitsubishi updated the 2G head with narrower ports in order to keep inlet velocity up and therefore help low and midrange torque. Switching to a 1G head might net you some more available flow on the top end, but without other mods you are unlikely to see any of that benefit while still seeing the downsides of the lower velocity on the 1G head and intake manifold. We're actually starting to see things go the opposite way, where 1G people are swapping to 2G heads for the higher velocity and more optimal flow angle.
Assuming that the N/A heads follow this same pattern, you would be better off keeping your 2G head if you're otherwise keeping it close to stock.
You're thinking about the other way around. He's has a 7 bolt. There is no machine work to be done when putting on a 6 bolt head.
As for the OP and the head swap. There will be no gains. If anything you might lose power from the lost velocity of going to larger ports because you are NA.
I didn't specify which way was which because I wasn't sure. I had a feeling that it was the 6-bolt that used larger head studs. Thanks for affirming that.
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
