ECMlink 1G First start issues
Bock
5+ Year Contributor
94
74
Jun 13, 2018
St-Jerome, QC, Canada
Hey guys, finally had time to start messing with link and my rebuild engine.
This is not my first time with link (did my 2G few years ago) but im feeling kinda rusty.
Im having some issues and would like yo have some of your input.
Engine is a stock rebuild
Stock everything beside SD setup/walbro255 (rewired)/fmic.
Stock 450cc/FPR
No boost leak and base timing done
The car is idling super rich (as of my new AEM X-Series 30-0300). 9.x:1
This is my first time with this WB (was using innovate for my previous build).
Did not change anything in the fuel setting (stock 450cc).
Im stock in open loop, my stock o2 look to be dead (not cycling) but when i tried NBsimulation, o2 is still not cycling.
So im looking for some advice, can it be from my WB ? or is the walbro causing to high pressure (increasing fuel?).
By the time i'll go look for a stock o2 replacement.
Your log shows you are stuck in Openloop. You might have a failed sensor somewhere. Your Airflowperrev is way too high as well. Maybe you have a boost leak somewhere. Or your MAP is not plugged in correctly.
yeah i know for airflowperrev, didnt touch it for now, im figuring out the fuel issue first. No boost leak and map looking good.
