Jyrka77
- 0
- May 12, 2015
Tallinn, Estonia,
Europe
Hi! I read numerous threads on clutch pedal problems, but didn't find an answer, so...
1G clutch does not disengange. Clutch pedal has no pressure and moves freely to the floor. Master cylinder is full of liquid, no signs of leakage.
Checked the pedal assembly under the dash.
I noticed that when I press the clutch pedal with hand, then the clutch lever and pushrod move just a bit, but then stop and go back to original position, all while I press the pedal all the way to the floor.
I assume that the lever should be rigidly fixed to the pedal, so this behavior is not normal? So the connection between pedal axle and lever is broken/worn? (see the snapshot from the manual)
Thanks
Jörgen
Thanks
Jörgen
