1990TSIAWDTALON
Moderator
- 13,322
- 11,402
- Nov 14, 2013
Independence,
Kansas
Great job!
Try Krylon #1403 Dull Aluminum for that "fresh" aluminum look on older parts.
I keep 3-4 cans on hand (along with Krylon #1613 Semi-Flat Black - NEW #51613 for that NEW Black Plastic look).
Here is an example:
Old Wieand SBC intake:
Same Intake Sprayed with Krylon Dull Aluminum #1403:
Installed on motor (water pump also painted with it, but it needs a fresh coat):
Here is an example:
but it always lasted unless you get gas on it, but then a touch up and it's all fresh again. I'll see if I can scratch the water pump paint, it's been on longer and had heat cycles.
Also, awhile ago I must have broken my A pillar trim
bummer.
